newtor avatar image
newtor asked
Standby Battery Charger
We have small installation comprising 5*200W panels, MPPT 100/50, Cerbo GX and 4*110Ah batteries, running a remote amateur radio repeater station and emergency radio communications for RAYNET.
We are considering installing a mains battery charger (We still have mains on site), controlled by the generator relay option on the GX to switch the charger on at a low battery voltage.
My question is, can we connect the battery charger directly across the battery through a suitable high current diode, with the same in the feed to the battery from the MPPT 100/50.
Thanks in advance. (Colin)
battery charging
Erik Sporns avatar image
Erik Sporns answered ·
Im using a dc-dc charger in my van to charge the batteries occasionally. Im also running the 100/50. I did not put in a diode and never noticed any issues. Id suggest that it would work without the diode.
wkirby avatar image
wkirby answered ·
You can connect the mains charger directly to the battery.
There is no need for any diodes at all.
