tator avatar image
tator asked
programming DMC with a Multiplus 3000
Trying to configre the DMC to set a current level for my genset that is higher than my shorepower setting (V.E. Bus Multisystem+external transfer switch). I have initially used VEconnect to set up the Multiplus parameters. With the DMC and Multiplus on, when I push the button on the back of the DMC to start the programming nothing happens-no flashing LEDs. What am I missing?
Digital Multi Control
Paul B avatar image
Paul B answered ·
Please send some pictures of what you are doing - as a DMC usually has no programing requirements at all
All you do is turn the limit switch The max setting is the Multiplus units pass through relay size ie 16amp or 50 amp
tator avatar image
tator answered ·
According to the manual "To enter the configuration mode press the button on the back of the DMC until the bottom LED in the left column starts flashing, indicating that the parameter can be changed." I push the button. Nothing flashes.
nerf9028 avatar image
nerf9028 answered ·
This is happening with me too so looking for an answer. I've attached photos of me pressing the button on the back of the DMC. I've held it down for 10-30 seconds, quick presses etc. Also tried it with all 'charger only', 'off' and 'on' switch options. Still no flashing lights to configure it.
tator avatar image
tator answered ·
I guess this is too complicated for Victron to figure out...sigh.
