I've been using the Venus OS on an RPI 3b+ since 2.53, and it's worked great, other than having to redo the same steps to enable the RPI backlight timer and dimmer controls.
I have an OSOYOO 5" DSI Touchscreen which has worked flawlessly up until v2.7 where the dimmer and backlight controls can't be re-enabled.
What used to work was:
echo /sys/class/backlight/rpi_backlight > /etc/venus/backlight_device echo /sys/class/backlight/rpi_backlight/bl_power > /etc/venus/blank_display_device cd /u-boot/overlays wget https://github.com/PiNet/PiNet-Boot/blob/master/boot/overlays/rpi-backlight-overlay.dtb opkg install kernel-module-rpi-backlight
Which enabled the dimmer and timer.
Does anyone have instructions on how to do this with 2.89 or 2.90?
