bruno-braun avatar image
bruno-braun asked
7" Touchscreen Problem with the touch
Hello together,
I installed the Victron Venus OS Version Firmware 2.66 but i have a Problem with the Touch function.
I have a Raspberry PI Model 3 and a original 7" Touchscreen.
https://obenschlaefer.com/low-budget-energiemonitor-victron-venus-os-mit-raspberry-pi-obenschlaefer/#Touchscreen_aktivieren
here i get a manual.
with the "opk update" i get a error message.
i tryed "/opt/victronernergy/swupdate-scripts/set-feed.sh candidate" also
but i cant get the "opk update" so i cant install the mousedriver.
Can you held me, thanks a lot.
Greetings
Venus OSRaspberry Pitouchscreen
Kevin Windrem avatar image
Kevin Windrem answered ·
I haven't looked at the Pi 3 but on Pi 4 models, the touch works without any modifications or additions. All that needs to be added is an overlay and some files in /etc/venus to support dimming and blanking. The package below helps making the necessary changes:
https://github.com/kwindrem/RpiDisplaySetup
But again, this package does nothing to make touch work.
vassilis-bourdakis avatar image
vassilis-bourdakis answered ·
Rpi 3B+ with original 7in touch works fine on anything I've tried over the last couple of years.
However, don't remember starting that low (2.66 I mean!) Any reason you're not installing anything more recent?
Kevin's s/w works fine and you need nothing more than that to have the screen and touch working properly.
If I were you, I'd try the latest release 2.82 or 2.83
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
