stevenew avatar image
stevenew asked
Blue Smart IP65 24/8 charging 2 battery banks possible?
I have a boat that has two 24V banks (starter/house), and a 1-both-2 manual switch - it seems that previously an old changer was connect on the house side.
I plan to change the type of house bank to AGM/Gel so also ending up with two different types of banks.
I wanted to do the same with the new charger - but would not expect it to work as intended unless I have a Cytrix ct to combine those.
Is that a correct assumption - or is the battery combiner unneeded?
Would a 2 (or 3) output charger had been a better choice?
battery charging
