Need to connect Multiplus 2 with pylon BMS directly to control LiFePo4 battery via CAN bus or RS485. Can enyone help me.
You need a GX device. You cannot connect the battery to a Multiplus directly.
Is this the same as pylintech? If so have you done a Google search?
https://www.google.co.uk/search?q=pylon+bms+victron&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari
Returns lots of links, YouTube videos and configuration guides have you read any material or user manuals? Specific questions are easier to answer.
Guys, but how to use RS485 (w/o CAN) from battery to connect to Cerbo GX?
You need a driver that can do that for you and then it depends on the BMS you use.
33 People are following this question.
