smithie1623 avatar image
smithie1623 asked
Smart BMS 12/200 with Smart lithium
Good morning All
I have an issue that i don't seem to be able to get around an i was wondering if i could use the Smart BMS 12/200 to do it.
I have a unit that takes power via a single 35mm battery cable but also gives charge back when plugged into the mains via the same cable.
Can i use the Smart BMS 12/200 system + side to control this so that the batteries are happy and wont over charge or go low voltage?
I have a working setup with the cyrix relays plus a battery protect controlled via the VE.bus BMS and two diodes to stop reverse current.
Lithium Battery
Perhaps a rough circuit diagram could explain you situation a bit better?
