Ben Johnson avatar image
Ben Johnson asked
Cyrix-Li-charge does it work without a BMS
Hi I’ve got some non custom lifepo cells which I want to charge with a foreign moot solar charge controller and wondered if it’s acts as a simple relay.
As in the manual it says it waits for the BMS before engaging disengaging. If it doesn’t then I’ll just use a SBP to handle the incoming solar charge rather than the Cyrix-li-charge. Also I can’t find any spec on its exact paras. It would be amazing if they made something that does both the charge and discharge In one unit controllable via Bluetooth, rather than having to have to stand alone SBP
battery chargingLithium BatteryCyrix Battery Combiner
Michael Riley avatar image Michael Riley commented ·
Have you also seen the 'Cyrix Combiner Kit' brochure/flier. It has some detail which may be additional. The 'title' is as per above if you search the Victron site if should come up.
Martijn Coster (Victron Energy Staff) avatar image
Martijn Coster (Victron Energy Staff) answered ·
Hi @Bennyj,
The Cyrix Li-charge needs a high signal on the BMS charge disconnect input.
Normally you would use the output from a BMS. But you van also use an other high signal.
best regards
Martijn Coster - Victron Energy
Battery Compatibility
Product page Cyrix Battery Combiner
