Duncan Hall avatar image
Duncan Hall asked
Duplicate VRM instances
I have a raspbery Pi running V2.85.
I have both a Multiplus and a MPPT attached.
They both are displaying the same VRM instance of 289 and dont retuern the correct product ID etc.
see below.
This leads to the multiplus having 2 entries on the controlls.
Is there any way to fix this.
VRM
jx-99 avatar image
jx-99 answered ·
I have the same problem. Even when I delete the #289 Multiplus in the device list, it is still shown in the dashbord control.
jetronic avatar image
jetronic answered ·
I have the same problem with a Multiplus 2 5000, which is displayed once with VRM-ID289 and once with ID290.
The Multiplus is actually always detected with ID289, I could see after reboot my Pi4 with Venus OS v2.92 though. That the Multiplus 2 also once with the ID290 been recognized, after a reboot was then again ID289.
In the VRM portal, I could then delete the Multiplus with ID290, but not from the "Realitime" list.
home-pv-newbie avatar image
home-pv-newbie answered ·
I have an similiar issue, but not yet seen a solution above.
I have set up my initial Home PV system (if needed, see details below in German), and it runs quite OK as an ESS system.
What I am wondering: in advanced VRM, 2 instances appear for VE.Bus and serial battery, and after reboot of the Pi running Venus OS v2.92, either one (e.g. 289) or the other one (288) is active:
This results in the need to have 2 widgets in VRM to show he actual data in either the one or the other:
==> how can I ensure that for VE.Bus and serial battery only 1 instance is used, consistently?
FYI my setup:
4x Trina Vertex S TSM-425DE09R.08 425 Wp Solarmodule
DEYE SUN2000G3-EU-230 Microwechselrichter (auf 600W gedrosselt mit Zertifikat)
victron Multiplus 48/5000, über MK3 USB am "Cerbo", ESS und DVCC aktiv
Pi mit venus OS als victron Cerbo Ersatz
D1 mini IR Lesekopf am Smartmeter mit Tasmota, dem "Cerbo" über JUFtoGridMeter.py als EM24 vorgegaukelt
16x EVE LF280K Akku mit JK BMS B2A24S20P , über RS485-USB Interface am "Cerbo"
