lonebeagle avatar image
lonebeagle asked
Does a BlueSolar PWM 48V 30A need to be in the light?
I built a pontoon boat with a 48V outboard and the SLAs were not getting the job done so we are changing to lithium. I am adding a cobbled together solar charging system and was planning to mount the BlueSolar PWM 48V 30A inside the console. Will this work? If not, will a small daylight source (a hole) work?
BlueSolar PWMmarine
kevgermany avatar image
kevgermany answered ·
The PWM doesn't need light, but it does need ventilation.
Panels are the parts that need light.
lonebeagle answered ·
Thank you! I had convinced myself otherwise
