ianddindustries avatar image
ianddindustries asked
Lynx BMS auxiliary and cerbo gx
Hi
I have a system with a lynx smart bms powering a cerbo gx from the auxiliary terminals, when the lynx is switched off via the remote control, the cerbo is still switched on and reporting to vrm. I thought that when the lynx is turned off via the remote terminals the auxiliary power would be switche to off as well?
Thanks Grant
lynx shunt
nickdb avatar image
nickdb answered ·
Can you provide a little more info about how you are doing this? It sounds like you are putting it into standby, perhaps via the soft switch?
ianddindustries avatar image ianddindustries commented ·
Hi I am turning it off via a remote switch (pin 10,11) and also tried via victron conect app using the off switch. no matter what there is always power to pin 1 I have checked the cables and have can terminators in the cerbo and lynx even with the terminal block completely pulled out of the lynx there still is power to pin 1 I have 2 systems side by side and both are doing the same thing? am I missing a setting in the lynx?
Lynx Shunt VE Can online manual
