lawsonsparks avatar image
lawsonsparks asked
battery low alarm on battery and inverter
installed 4 pylontech batteries through Multiplus II GX inverter andMPPT 250 controller . no mains . After 3 weeks its now giving low battery on the inverter and all batteries are in alarm . Battery vlotage is 56.7 V .
What do i need to alter in the settings
low battery warning
jeanmarie avatar image
jeanmarie answered ·
which pylontech model are you talking about?
Because standard ones are 15S models, meaning 56,7V for the pack correspond to 3,78 per element : this is bad for your battery life
nickdb avatar image
nickdb answered ·
Go step through the pylon setup guide properly. It sounds like something is misconfigured.
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
At that voltage, if it is correct, you will be trying to cook the battery.
