pablosol2 avatar image
pablosol2 asked
ESS and AC coupling on Quattro inverters
Hi all,
I have two PV Huawei inverters connected to AC output (critical loads). When I produce more energy than what is consumed I feed in the public grid and I never see power I am using (only the exported to the grid). I can only know the power I am consuming when I take it from the grid.
Battery charger is not working properly and I wonder if the reason is that I do not have a energy meter installed (ET112 for example). I am overproducing electricity and batteries do not start charging. ESS is activated and properly setup but I don't know why this behaviour
Thanks
battery charging
