mianfrar avatar image
mianfrar asked
EM-111 and 2.90-14
Hello I have version 2.90-14 large installed. I updated from 2.72 large because there was a problem with the louisvdw bms driver that was fixed in the latest versions of the driver. As a meter I have the Carlo Gavazzi EM-111 (if the 111, not the 112), the problem is that sometimes it measures with a changed sign and it is solved with a restart, before that did not happen and I do not know if it will be from this version or from another previous. Is there evidence of incompatibilities with this counter? I have entered the counter configuration with the Carlo Gavazzi software and it does not matter if I put the configuration A or B since Venus changes it even by putting a different access code.
Energy Meter
