jerothle avatar image
jerothle asked
Lithium Charging Victron Chargers
Hello, how long can the Phoenix Smart IP43 50A charger (or any Lithium charger) remain "on" and connected to a 12 volt Lithium battery system?
Currently the charger is in "Storage" mode with about 0.9A to 1.1A at 13.50V going into Lithium batteries with a BMS controller.
There is Victron Smart MPPT and Orion-Tr Smart B2B chargers connected. There are also two 12 volt compressor refrigerators, a POE switch powered by a 12 volt to 48 volt converter, Sierra Wireless cellular modem/router, Cisco POE access point, other things that are not always on: two Victron Inverters, etc.
Regular consumption is about 1.5 amps (with no charger connected, no refrigerator compressor running).
Thank you, Jeff
battery charging
johanndo avatar image
johanndo answered ·
Indefinitely, they would supply your loads and keep the battery at the set point voltage (in your case 13.5V float)
