Hi, is there a way I can see the input and output power or any data on a parallel setup in vrm or something?
I have a gx 48/5000 in parallel with a 48/5000 GX
As you have a GX unit then connect that GX unit to the internet and then connect it to the vrm , you can then logon to the vrm and see all the in and out power figures and a live feed as well
27 People are following this question.
