ignascyvas avatar image
ignascyvas asked
SmartSolar MPPT 100/30
1) I was wondering if 'External fuse interrupting rating - 40A min up to 50A max' means that the external fuse I install between the solar panel and the charge controller or between charge controller and the leisure battery is restricted to 40-50A.
2) To connect the cable to solar charge controller is a ring terminal needed?
All the best,
Ignas
MPPT Controllerssmart solar set-up helpinstallation
Ceki Gabay avatar image
Ceki Gabay answered ·
1- It restricts the current between charger and the battery.
2 - I did not use on my both chargers.
MPPT Product Page
MPPT Error codes
