Rabeendra Tilakaratne avatar image
Rabeendra Tilakaratne asked
LiFePo4 battery connection
I need to connect the controls of Multiplus II with 3rd party 48V 200Ah LiFePo4 battery. Can I connect the battery directly to CAN bus or RS485 without any accessory to monitor and control the battery BMS.
Lithium Battery
nickdb avatar image
nickdb answered ·
It depends.
You need a GX device in the system for CAN connectivity, it can't connect direct to a multi.
It also needs to be a supported monitor:
https://www.victronenergy.com/live/battery_compatibility:start
Though third party devices may work fine, just unsupported.
Some BMS may require you to use an RSxxx connection, some local devs have produced a driver for the GX which enables this:
https://community.victronenergy.com/questions/76159/victron-venusos-driver-for-serial-connected-bms-av.html
Again, support is between you and the battery/bms manufacturer.
