helmutm avatar image
helmutm asked
Which Cerbo GX FW to use with Cegasa eBick BMS TCC-CAN v02
i like to connect a Cegasa CAN BMS to the Cerbo BMS CAN Port (CAT5 straight, terminator plugged in), but it wont be recognised an doesn't show up as a Battery Monitor.
The Cerbo has the most recent FW version from the release feed installed which is v2.89. The troubleshoot section of https://www.victronenergy.com/live/battery_compatibility:cegasa states, a firmware version v2.90 or later is to be used. Is it advised to install a v2.90~ from the release candidate feed?
Thank you!
best regards
Helmut
cerbo gxBMS
nickdb avatar image
nickdb answered ·
Support was only added in the 2.90~12 RC, so yes, you will need to run the RC if you want support ~14 is the current release.
See the topic in the modifications section.
helmutm answered ·
Thank you for the answer. It works after updating to RC 2.90~14
