Lyndsay Cotton avatar image
Lyndsay Cotton asked
3 Phase Quattro sequence error
Hello Community
I have search all the Q&A here however cannot find the answer.
New install 3 x Quattro 8kVA, EM24 Ethernet energy meter, Cerbo GX.
I completely rebuilt the main DB from the supplier (Utility) pole. The phasing has been religiously followed from the Utility right upto the quattros.
I cannot get the system (EM24) / (Cerbo) / (Quattros) to start up. A phase sequence error continues to be reported.
How is this possible?
Why can't I set the EM24 to report the correct sequence. Or the sequence that we want. This is a large existing facility.
Why can't I (How can I) set the Quattros to accepted my sites phase sequencing.
What, How can I fix this? Surely the existing site sequence can be maintained- IF this is the reason?
Much appreciated
3 phase
Alexandra avatar image
Alexandra answered ·
@Lyndsay Cotton
The inverters would usually have to be programmed for their relative phases. So if there is a sequence error then they were programmed for a different sequence.
Or you just change the wiring.
https://www.victronenergy.com/media/pg/Venus_GX/en/ve-bus-inverter-charger-monitoring.html#UUID-08b41a43-2b6b-f012-e2f5-f4db25ae659b
