jgrahamca avatar image
jgrahamca asked
Venus GX Tank Input
I have my current tank level sensor wired up to the boats analog gauge sensor terminal "S" and ground. Can I just jumper the S terminal to the input of the Venus GX? I don't want to damage the tank level input of the GX if it supplies its own voltage across the sender sensor resistance.
Venus GX - VGXtank monitor
wkirby avatar image
wkirby answered ·
The analogue guage will present a Voltage to the Venus (and the Venus will have its own Voltage source too). The two will interfere with one another and produce false readings at best.
jgrahamca avatar image jgrahamca commented ·
That's too bad. Thanks for the response.
jgrahamca answered ·
I got a response back from Victron support and they stated that input is powered using a 5V supply.
