lawrence-craig avatar image
lawrence-craig asked
Abs Voltage High - SmartSolar - Consistent Temp
Hi all.
I can see this question has been asked before but the answers seem different from my situation.
I have SmartSolar (x3) with VE Smart Network connected to SmartShunt, Multiplus (Off) and RPi running Venus OS (DVCC off).
Today, the Abs voltage was +0.4v over target (14.4v). I am in Greece where the current batt temp is 25C and was likely same temp this morning. Temp compensation is -16.2mV/C.
Why else would the controllers be taking Abs voltage to +0.4v?
Images below.
Thanks.
screenshot-2022-07-13-at-132830.pngscreenshot-2022-07-13-at-135056.pngscreenshot-2022-07-13-at-132901.png
MPPT ControllersSmartShuntVE.Smart Network
4 comments
Why are you using VE.Smart Networking if you have a GX/Venus OS device?
Why is DVCC off?
What is set as battery monitor in the GX device?
lawrence-craig avatar image lawrence-craig seb71 commented ·
I have connected using VE Direct to USB to the Pi and been told that the DVCC only works over Canbus. When I try use DVCC, I find the 3 chargers don't synchronise on charging phase. When I go to the status on VenusOS, the units say they are not networked and acting as standalone. I have raised this here (https://community.victronenergy.com/questions/144067/dvcc-on-raspberry-pi.html?childToView=144069#answer-144069)
Battery Monitor is SmartShunt.
seb71 avatar image seb71 lawrence-craig commented ·
When you tried with DVCC on, did you also enabled Shared Voltage Sense, Shared Temperature Sense and Shared Current Sense?
And without also using VE.Smart Networking.
Yes to all and with VE Smart Networking turned off.
