johanndo avatar image
johanndo asked
VRM Widget - use the same scale for values with the same unit.
Hi, a suggestion to the developers.
The widget in VRM is very handy to group and compare values by the user in the VRM portal, however it ends up in having a different scale for each data set, what is very confusing / frustrating.
It would be easy to pick a common scale for data rows with the same unit. (Volt, Ampere, °C, Liter or whatever) If the data sources have the same unit, use a common scale factor. Would make things much easier and user friendly!
Thank you for considering.
VRM
kevgermany avatar image
kevgermany answered ·
I'm assured it's on the list to do. Thanks for the suggestion.
cvo avatar image
cvo answered ·
Is there any update on that? It's been a year and this would be a really useful addition.
You can make custom widges and there you can set the same scale on Y-axis for all parameters you selected for that widget.
