My GX touch 50 keeps rebooting. I did post this on another thread as was told it was being investigated and then that thread was closed. Reposting and hoping it’s picked up again
Thanks
Trevor
This thread?
https://community.victronenergy.com/questions/131941/touch-gx-and-i-assume-cerbo-rebooting.html
Usual causes for Cerbo rebooting are either poor internet connection, or too many connected devices overloading it.
Poor internet connection reboots can be configured by you. Otherwise check for excessive connections by removing devices.
No it was another thread where one of the Victron guys said it was being investigated then closed the thread. it’s at the bottom of this thread
@kevgermany hi and thanks for your thoughts. When you say "Otherwise check for excessive connections by removing devices." - what kind of devices do you mean? My Cerbo GX has a Touch 50 screen attached and it is rebooting, freezing and dropping Wi-Fi really badly. When I disconnect the Touch 50 the problems stop. So I am looking for the underlying cause.
My Cerbo GX is connected to:
That all seems within the spec as I understand it. The Cerbo GX is receiving >13 volts power supply. I have also checked the Wi-Fi/Touch 50 interference problem, my unit was manufactured after they fixed that fault, I opened it to check. And I am familiar with the lost internet/reboot parameter.
Thanks very much if you can shed some light, this is driving me mad...
You have the usb port next to the hdmi port connected to the Touch 50?
Does the problem still occur if you disconnect all the Ruuvi sensors for instance? If not, can you add some back?.
Looks like you do have many to deal with.
27 People are following this question.
