bishop avatar image
bishop asked
Color control GX as a monitor only?
I already have the color control GX from the original RV install a year ago. I would like to use the Cerbo GX in the new install to combine all the Victron devices and only run one connection to the Color Control inside as the display. I know it is redundant to have both. But I do not want to have to cut a new hole for a new screen install. Thank you!
cerbo gxCCGX Color Controldashboard display
I don't think there is an easy way to do that. But there is an adapter for the GX Touch 50/70 to cover the CCGX cut-out.
https://www.victronenergy.com/accessories/gx-touch-50-adapter-for-ccgx-cut-out
