paulm avatar image
paulm asked
Venus OS Large not working with Waveshare HDMI 4" Touch Display
I have Venus OS 2.87 running on a Raspberry Pi3 with a Waveshare HDMI 4" 800 x 480 Touch Display from Pi-Hut with no problems. It's set up according to the Waveshare instructions by adding ....
hdmi_mode=87
hdmi_cvt 480 800 60 6 0 0 0
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
display_rotate=3
... to the end of the /boot/config.txt file and renaming '/etc/venus/headless'. The touch display isn't configured (yet).
I've tried the same setup on Venus OS Large 2.90~14, in order to make use of Node-Red, but all I get are multicoloured horizontal lines on the display. The remote LAN display in my browser is also rotated 90 deg clockwise. I haven't tried VRM. I can restore the remote display in my browser by using 'display_rotate=2' but had no luck with getting the Waveshare display working with Venus OS Large.
Is the underlying Raspberry Pi OS different between versions ??
PaulM
Venus OSRaspberry Pihdmi
jaap-spies avatar image
jaap-spies answered ·
First, Venus OS is not Raspberry Pi OS!
I don't have a Waveshare 4" touchscreen montor, but I had simular problems with a simular touchscreen from AliExpress: http://www.lcdwiki.com/4inch_HDMI_Display-C
The product parameters are almost the same. You can't use the install scripts because they are specific for Raspberry Pi, but reading the script MPI4008-show you can see what is needed in config.txt
[jaap@vrede ~]$ ssh root@192.168.178.103
root@192.168.178.103's password:
Last login: Sat Jul 2 16:18:22 2022 from 192.168.178.17
root@raspberrypi4:~# ls
LCD-show         LCD-show.tar.gz
root@raspberrypi4:~# cd /u-boot/
root@raspberrypi4:/u-boot# cat config.txt
enable_uart=1
kernel=u-boot.bin
[all]
device_tree=bcm2711-rpi-4-b.dtb
hdmi_force_hotplug=1
hdmi_force_edid_audio=1
dtparam=i2c_arm=on
dtparam=spi=on
display_rotate=3
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_drive=2
This works for me (almost). Touching the label 'Pages' does not work!
I'll open a question on this.
kevgermany avatar image
kevgermany answered ·
@PaulM
Better here in modifications
@kevgermany
I don't understand the move to modifications. Since the problem is related to the way venus os works on a Raspberry Pi. The RPi's don't have a BIOS, so coupling basic hardware such as a screen has to be done in the so called 'config.txt'.
I suggest reading:
https://www.raspberrypi.com/documentation/computers/config_txt.html
Please have patience with me. I'm new here :-)
Hi Jaap
Pi related questions should be in modifications.
Take a quick look at the guidelines:
https://community.victronenergy.com/questions/5889/new-victron-community-guidelines.html
Sorry, but I don't have the Pi knowledge to help. But there will, hopefully, be a Pi expert there who can help. But less likely in Q&A
paulm avatar image
paulm answered ·
Many thanks, that works perfectly :-) I'm not using the touchscreen at present.
My comment re Raspios - the waveshare display works, as supplied, with Debian Buster based OS but not with Debian Bullseye. I guess that's the difference between Venus OS and Venus OS Large ?
Regards
PaulM
an1uk avatar image
an1uk answered ·
Considering buying this display. Does the backlight dimming/off and screen off features work?
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
