zhurkinva avatar image
zhurkinva asked
Easy solar and Multiplus in 3-ph or parallel
Hi! Easy solar includes Multi plus, MPPT and CerboGX in one package.
Can a similar multi plus be used for a parallel configuration vith Easy Solar?
Is it possible to use Easy Solar and some Multi Plus to create a 3 phase configuration?
Thank you for answer.
EasySolar All-in-Onemultiplus in parallel
marekp avatar image
marekp answered ·
@zhurkinva
Yes, you can set-up 3-phase system consisting of 1 ES-II and 2 MP-II.
They have to be the same size and, for best result, close in production dates.
3-phase system is less picky if the production date is concerned.
Parallel is a different story. In parallel system all units should be from the same batch.
I have 3-phase/2 parallel system with 1 ES-II/3k and 5 MP-II/3k.
Even thou I have such a system, I am changing to system with 3 MP-II/5k.
BTW.
The GX inside ES-II is not Cerbo GX. Cerbo GX has allot more inputs and outputs.
If you planing to buy ES-II and 2 MP-II to make 3-pase system I would sugest to buy 3 MP-II, Cerbo and MPPT as a separate units.
ES-II with the MPPT inside of it is getting warmer than MP-II.
If you want to read about my problems with such system.
https://community.victronenergy.com/questions/91403/how-to-balance-2-mp-iis-in-parallel.html
zhurkinva answered ·
Thank you!
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
