windydrew avatar image
windydrew asked
Working on EMUS G1 to Victron Quattro Parallel with Venus GX
Having an issue controlling the Quattro Charger. Have installed the Victron EMUS firmware. I am getting readings in the DCVV and everything seems right except that it doesn't charge. There's no errors in EMUS either. It has a check for charger enabled also so I don't understand why it won't charge. Do I need to wire up a charge enable to the inverter?
MultiPlus Quattro Inverter ChargerBMS
