Hi there
I have a multiplus 3000/230v and I do not manage to get any voltage on the AC Out 2 when connected to the grid.
Is there any magic to get this to work??
cheers
Hi there
cheers
Hi @Seb71
thank you for your reply
I have the multiplus connected to the boat generator and the battery bank. On the ac out 2 i connected the ac input for the Air Con and the water heater, but when the generator is running (or I have the input from the Grid connected) the AC OUT 2 does not outputs anything. Today I had the generator running for over 30min but the AC OUT 2 never got powered up.
I have taken voltage measures at different points of the system and I can confirm that voltage from the generator is reaching the AC Input. If I set the multiplus to ON, the multiplus will start charging the batteries, thus, confirming that it does receive voltage, yet, AC OUT 2 remains without power.
Any ideas on how to configure it?
Cheers
Hi
No assistant configured. Do I need one for the AC OUT 2 to work?
I tried yesterday and created one that would enable the AC OUT 2 when AC IN on, and ended up running the Aircon from the batteries for 5 min by mistake...so I deleted it
Cheers
is there any flag that need to be enabled?
Thanks
That behavior can be overruled with assistants. Maybe you try a factory reset of all settings or you configure two assistants (one for on and one for off) to "rebuild" the default behavior.
28 People are following this question.
