ako avatar image
ako asked
Sense Wire Multiplus 1200
The Multiplus 24/1200/16 comes with a temperature sensor and VE con figure shows the option to set the temperature compensation adjustment but i cant see where a sense wire to compensate for cable variations would connect , without knowing the accurate battery voltage then Temperature and compensation values are worthless when charging or am i missing something . A sense wire can be critical on a charge controllers so surely an Inverter Charger should also need one .
sensor
