merav avatar image
merav asked
Easysolar not diconnecting my system when the batteris are low.
My solar system is EasySolar24/1600 and BMV-700.
However, last week the batteries went down to %0 (because the solar panels got disconnected by accident for 2 days).
My understanding was that the Easy Solar need to disconnect the system at factory setting to protect the batteries from ever going down to %0.
Any thoughts on what is wrong here ?
Thank you very much
merav
EasySolar All-in-One
klim8skeptic avatar image
klim8skeptic answered ·
What values have you programmed the Multiplus regarding low battery shutdown?
Note, the Soc in the above shot refers to the multiplus's calculated Soc, not the BMV readings.
@merav also the easysolar cannot control DC loads
merav avatar image
merav answered ·
The unit was programed by a friend, who is not available to contact now.
Unless you can find someone else to help, you must monitor manually. But also look at loads connected direct to the battery.
