Martin avatar image
Martin asked
MPPT 100/20 ePropulsion e80 settings
Hi Brainstrust,
I'm setting up MPPT 100/20 solar charging for an e80 ePropulsion battery on a trimaran (running the Navy 3.0 only) and have been advised by ePropulsion that:
Is there a setting for controlling charge cut-off if the solar drops below 1A?
I can't see one in the manual although it may be called something I don't recognize.
thanks
battery charging
ctboatguy007 avatar image
ctboatguy007 answered ·
martyd have you had luck using a solar panel and Victron to charge your E80
Martin avatar image
Martin answered ·
Hi, I didn't get any feedback to that initial question and I have had issues with charging. The solar charging will work OK if getting good power however if left overnight it seems to confuse the BMS and I've had a few fault conditions as a result. fixed only with a solid 240v charge. I now only charge in full sunlight and disconnect at other times. pretty annoying. Maybe a 1A cutoff would fix the issue.
