ejm avatar image
ejm asked
Picking a battery bank
I have the Victron Quattro 48 volt and want to start a new battery bank with lifepo4 instead of lithium ion that I currently have. What manufacture works best with Victron and is the best bang for the buck? Also could you recommend the best place to buy them I am in the northeast/New York.
Lithium Battery
nickdb avatar image
nickdb answered ·
Start with the supported list:
https://www.victronenergy.com/live/battery_compatibility:start
Cost per kWh varies but you also have to consider discharge rates.
Pylon is good value, as an example, but you need more modules if you want to power a decent load.
Document your requirements then pick one which has the best support in your region (with a good warranty), and offers a good cost per kWh at the loads you expect to run.
ejm avatar image ejm commented ·
Thank you for the link. If anyone knows a good place to buy batteries in the northeast please let me know. Thanks
