trail avatar image
trail asked
flashing lights on charger after failed firmware update
Just installed a Blue Smart IP67 120v. 24/8 on my boat. Charger was working fine...until I downloaded the app, and then did the software update as directed. The update failed at approx 92%...3 separate times. Now, the green and yellow lights are flashing, alternately, very quickly. The charger is now unplugged, and after a while the flashing has stopped. What is my next step?
Thanks.
firmware update
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Trail
Can you please try the following:
- Update the charger while only connected to AC and not connected to the battery
- Update the charger using a different phone
When this does not work and it still show this same behavior, can you please create a service report after trying to update the charger and paste that here in an answer or comment? The procedure for a service report is described here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
