tcwippy avatar image
tcwippy asked
Connecting Argofet Isolator to Paralleled Battery Bank
When connecting an Argofet Isolator to a battery bank with paralleled batteries, do you use one isolator output for the entire paralleled bank, or use multiple outputs, one for each battery In the paralleled bank? On my boat, I have a starter bank with a single group 34 battery, and a house bank with two identical group 31 batteries. I’m believe I need a two bank isolator but just wanted to confirm that I don’t need a 3 bank isolator. Thanks for your help.
Argo FET Diodedc isolators in parralell system
tcwippy answered ·
I spoke to a Victron distributor and he confirmed that the paralleled batteries should be treated as a single bank and only receive one output from the isolator. So in my case I need a two output isolator, with one output for the starter bank, and one output for the house bank.
Sarah avatar image Sarah commented ·
Yes - one output per battery bank.
