kanoa3160 avatar image
kanoa3160 asked
Auto start for CUMMINS C22D5
I have a Cerbo GX and looking to auto start a Cummins C22D5. The installer put in a two wire cable from relay 1 to the generator, but it is not working.
I have reviewed all the settings and tried simple SOC conditions as well as the manual start from the Cerbo controller. The relay clicks, so a signal is being sen t, but the generator does not start.
The Gen is in auto mode.
Does anyone know the wiring for the Cummins C22D5 generator?
In other ATS related questions there is mention of additional relays/circuitry required for a Cummins generator, is that the case for the C22D5?
Thanks
Calum
gen start
broadshield avatar image broadshield commented ·
Did you get this problem sorted out? I am about to start wiring up a C33D5 for remote start.
mjs500 avatar image mjs500 broadshield commented ·
witch control panel do you have fitted generator ?
mike-g avatar image
mike-g answered ·
It is certainly possible to build the required relays to do this, but the easy way out is here:
https://atkinsonelectronics.com/generator/
