kenamorosano avatar image
kenamorosano asked
Why does Multiplus show different voltage than BMV-712?
Multiplus 12/3000/120 is showing 13.95 Volts and is in Float and has stopped charging the batteries allowing a drop to 93% on the BMV-712 overnight.
BMV712 is showing 13.35 Volts and 93%
Multimeter check at batteries matches BMV-712 at 13.35%
Mulitplus has V Sense wire connected to battery positive terminal.
Batteries: 5 - SOK 205Ah Lithium for a total of 1030Ah
Anyone know why are the Multiplus and BMV out of sync and how to fix?
Multiplus-IIBMV Battery Monitor
wkirby avatar image
wkirby answered ·
Why did you only connect the V Sense wire to the positive terminal? What happened to the negative terminal?
kenamorosano avatar image kenamorosano commented ·
wkirby, any ideas on why this is happening. Both neg and pos v sense wire are in place.
Ken
kenamorosano answered ·
Yes. Both positive and negative are connected.
Anyone know why the Multiplus and BMV are out of sync and how to fix it?
zricha avatar image
zricha answered ·
Hi @KenAmorosano. Were you able to resolve the issue? I am facing the same but in my case, it is a Quattro instead of a Multiplus.
The inverter will read it's own terminals, it needs to do that for monitoring for things like DC ripple.
For charging if there is a BMV, GX and DVCC it should use the voltage there for the battery status and needs.
The ve bus SOC will synchronise the BMV SOC.
