Billy Newport avatar image
Billy Newport asked
CCGX with VECAN NMEA, BMV7** on NMEA?
I have a CCGX with a VECan NMEA cable. It have a multiple and 3 BMV VE Direct meter plugged in to the CCGX.
I can see some information on my plotter but I do not see an NMEA instance for each BMV plugged in to the CCGX. Is this supported? I also don't see a power out value for my Inverter NMEA device? Is there a document somewhere explaining what NMEA objects and values a GX device will push to NMEA when connected?
I have 2 3kw multiplus. one has a GX and the other a CCGX. Should I add an NMEA VE Can cable to those also or what do I lose by just using the CCGX NMEA link versus connecting the multiplus directly?
Multiplus-IIBMV Battery MonitorCCGX Color ControlNMEA 2000 - N2K
Hi @Billy Newport, there wasn't - at least not comprehensive. And now there is information, see here:
https://www.victronenergy.com/live/ccgx:start#marine_mfd_integration_by_nmea_2000
