andykirby avatar image
andykirby asked
Can’t see daily production from grid tie via grid meter
I have a grid tie inverter connected to my small system which consists of a blue smart solar charger, BMV Smart (on 200Ah LifePo4), Phoenix 800 and a raspberry pi running Venus software. I manually switch my PV between the victron solar charger and the grid tie inverter.
I am tracking the production of the Grid tie using a grid meter on its output, the grid meter is connected to the raspberry pi and it all shows up and works well.
Question is, I can see the grid tie showing as a PV inverter in the VRM but I can’t see any detailed stats like daily yield in the VRM, in advanced settings all I see is a graph showing the PV yield.
How can I see the daily yield in the VRM, sounds blazingly obvious but I just can’t see it.
Cheers,
Andy
VRM
Paul B avatar image
Paul B answered ·
you can download this in excel and then get the info you re looking for from that file
Hope that helps
