Should the 'charged voltage' as set up on the Smart Shunt be the same value as the float voltage of the system?
Hi @roachmon - in case you have not already sorted this out yourself, I think the accepted setting is 0.1 or 0.2 volts below the float voltage for your setup - whatever that may be
33 People are following this question.
