Hi Guys,
With different version of the Victron Multiplus 1/2 out now, Is there a compatibility chat-table of what can work together ?
I understand previously both devices must be identical ? is this still the case?
Regards
Hi Guys,
Regards
nothing has changed. All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set.
See also the Parallel, split- and three phase VE.Bus systems guide.
25 People are following this question.
