ferrodamian avatar image
ferrodamian asked
How to install inverter control to the inversor 12-800
I want to install this control to this inverter, how I can do this and if i need to change the dips.Thanks
Je veux installer ce contrôle à cet onduleur, comment je peux le faire et si je dois changer les dips.Thanks
Phoenix Inverter
Stefanie avatar image
Stefanie answered ·
@ferrodamian
The Inverter control does not work with your MultiPlus. It is supposed to work only with Phoenix VE.Direct inverters.
You may want to look for the Digital Multi Control (DMC) or Digital Multi Control GX.
ferrodamian answered ·
Thanks for your quick answer!
