I have. Two victron 25.5 v 200ahrs connected in series for a 48v system. What is the battery correct capacity setting. Is it 200ahr or 400amh. How can I set this remotely using vrm portal
Capacity is increased in parallel and voltage in series, so you have to enter 200Ah.
34 People are following this question.
Multiplus stays in absorbtion mode for over 12 hours with high voltage and 0 or low current
Quattro 24/5000/120 with 240V split-phase input
RV Inverter Upgrade: 12v vs 24 Inverter
Quattro will not stay in "charge" mode longer than 3 seconds
Absorption time should be settable to less than 1 hour with lithium
