Has anyone got a Idea re this as to how to solve it THANKS.
I am getting this warning, every time I reboot the cerbo and I cant seem to stop it from happening - I know its a minor issue but it should not be occurring.
The Quattro is 3 x 15000 48 volt units 3 phase Fw 496
Cerbo fw 2.85 and currently I moved it to 2.90~10 to see if this resolved the issue (Did not)
ess installed - Sustain set to 48v - country code set to other
low battery in the ve configure set to 41v
the ESS Dynamic cut-off is set to 45v - Sustain is set to 48v
I know these ESS low voltages are a bit low but I am trying to stop this warning.
Ess is set to (See picture)
NO BMV installed just using the quattros as the battery monitor.
Happens with the BMS software removed. however the BMS ess selection was Not removed for the test (See picture)
