Our water maker inlet hose, did come out of the filter splashing with water the Cerbo GX . All connections where wet, but inside was not water. It is an unfortunate episode, now the Cerbo GX is dead, There is something one can do to recover it?
If the CerboGX is completley dead it may be the fuse which resides in a smallll black tube on the power lead. Check the fuse and if the fuse is ok it may be the Cerbo has unfortunately died.
35 People are following this question.
