love2learn avatar image
love2learn asked
Multiplus 24/3000/70 50a charge limit
Hi all! I connected my laptop to the inverter and configured all the parameters for my system and battery type/capacity. However, connecting to the inverter via the Victron Connect app shows that the charge limit is set to 50a. When I try to increase this to 70a in the VC settings, it wont let me go above 50a. What am I missing here? How do I allow the system to fully utilize the 70a that the charger is able to handle?
MultiPlus Quattro Inverter Chargercharger
allswell avatar image
allswell answered ·
I had this same problem. I realized my battery was not set up in VE Configure for my Multiplus so I downloaded the file, edited the battery settings and also unchecked Weak AC. Uploaded it again and ran the system and it then charged with amperage up to 70amps instead of 50amps.
Hope this helps!
