Simon Coram avatar image
Simon Coram asked
Cerbo gx with an old phoenix multiplus
211c0230-41dd-41c8-910b-8e027e565e9d.jpegI have an older approx 2003 phoenix multiplus on my boat and have recently fitted a solar system with a victron MPPT and smart BMV.
I’m thinking about fitting a cerbo gx ( I’ve got one on my home system and like how it works)
Will it be comparable with my older multiplus?
So I can connect all 3 together through the cerbo.
I do have a router onboard so it will connect to that and I can remotely monitor it.
cerbo gxmultiplus ve.buspheonix
4 comments
Simon Coram avatar image Simon Coram commented ·
Thanks.
Where will I find the cpu type and firmware?
I’m guessing it was installed when the boat was built in 2003 so may be a bit to old but I you never know.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Simon Coram commented ·
Remove the front cover to see the main PCB with the CPU in the upper left.
On the CPU is a white sticker with a 7 digit number.
Simon Coram avatar image Simon Coram Matthias Lange - DE ♦ commented ·
Thanks
Simon Coram avatar image Simon Coram Simon Coram commented ·
This was the other label.
