In VRM, Device List, when i select "Firmware Update" is starts off normally but in the middle of the scan, it seems to get stuck with the message:
Status: No VE.Direct ping reply.
And then after sometime VRM states the following:
Firmware update use to work but stopped after I successfully updated my Multiplus firmware. Multiplus is directly connected to a Venus GX via the VE.BUS RJ45 Ethernet cable. Also connected to the Venus GX is a solar charger and BMV-712 via VE.Direct 1 and 2. VRM works normally and 2-way communication is enabled, the Multiplus also works fine and I can even do a "remote VEConfigure" via VRM. I have the following Multiplus
Any ideas?
Joe
