![victron-setup.jpg](/storage/attachments/33262-victron-setup.jpg)
Updating for the Lynx Shunt VE.Can is possible only via VRM: Remote firmware update or via a specific CANUSB adapter (needs to be purchased).
More on the above procedure: https://www.victronenergy.com/live/ve.can:updating_firmware
Since you have a Cerbo GX, I assume it's connected to VRM. You can check the device list on VRM for the Lynx Shunt and see if there is still communication going on (Last seen:...).
If that's the case, you can scroll down the page and try a remote firmware update via VRM. The firmware itself can be downloaded from https://professional.victronenergy.com in Firmware/Lynx Shunt VE.Can (need to sign up).
If that's not possible, the only way I see is to contact your dealer/distributor for a possible warranty claim or replacement.
29 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
