porcini avatar image
Minimum shore current limit | Multiplus 12/2000/80
I'm a little bit disappointed. I know it is my fault that I haven't looked for it before, but comparing the following models with their minimal current limits doesn't make sense to me.
MultiPlus 12/800-1600/35-70 - 2,4A
MultiPlus 12/2000/80 - 4,5A
MultiPlus 12/3000/120-16 - 3,1A
Quattro 12/5000/220/2x100(!!!) - 3,9A
I have installed a Multi C12/2000 to use with a small backup generator with 3.9A (900W). Since I knew the 1600 could go down to 2.4A I haven't expected that the only 300W stronger model has a much higher limit. When I then saw that there are even a Multi/Quattro 3000 and 5000 available with a lower setable input current limit I was really disappointed. What I have to do now is always turn loads off when charging with the generator, since power assist doesn't work. Well, yes, it's my fault.
Nevertheless I wonder if this could be changed. Is there a technical limit why this won't work, but the others do? I have seen that in some models it has already been reduced by firmware. I'm really wondering about the proportions of the different models. First I thought it has to do with the max. transfer capacity, but the Quattro has 100A!
Thank you for telling me the reason.
regards,
Porcini
MultiPlus Quattro Inverter ChargerGenerator
Hi Porcini, this is just what it is. If it could be changed, trust me, we’d have done it already.
Alright thank you. At least I have learned to keep my mind on limits before buying :)
nbezanson avatar image
nbezanson answered ·
Count yourself lucky, the quattro 12/5000 unit (model 2733) was originally 19A and has now been reduced to 13A. Systems with small generators will just need a separate small charger!
The varying limits surprised me too. I love 99% of Victron's features, but this is the other 1%, for sure.
Thank you for sharing your trouble. Looks like I am not alone :)
BTW: Comparing both the 2000 is even bader.
4,5A*230V/2000VA gives ~0,5x min.
13A*120V/5000VA gives ~0,3x min.
Quattro 12/5000/220/2x100 has ~0,18
--> The 2000 is the badest multi when comparing to the minimum shore current limit.
